5.2.1.1 OCNADD_POD_CPU_USAGE_ALERT
Table 5-1 OCNADD_POD_CPU_USAGE_ALERT
Field Details
Triggering Condition POD CPU usage is above set threshold (default 70%)
Severity Major
Description OCNADD Pod High CPU usage detected for the continuous period of 5min
Alert Details
Summary:
'namespace: {{ "{{" }}$labels.namespace}}, podname: {{ "{{" }}$labels.pod}}, timestamp: {{ "{{" }} with query "time()" }}{{ "{{" }} . | first | value | humanizeTimestamp }}{{ "{{" }} end }}: CPU usage is {{ "{{" }} $value | printf "%.2f" }} which is above threshold {{ .Values.global.cluster.cpu_threshold }} % '
Expression:
expr: (sum(rate(container_cpu_usage_seconds_total{image!="" , pod=~".*ocnadd.*"}[5m])) by (pod,namespace) > {{ .Values.global.cluster.cpu_threshold }}*2) or
(sum(rate(container_cpu_usage_seconds_total{image!="" , pod=~".*kafka.*"}[5m])) by (pod,namespace) > {{ .Values.global.cluster.cpu_threshold }}*2) or
(sum(rate(container_cpu_usage_seconds_total{image!="" , pod=~".*zookeeper.*"}[5m])) by (pod,namespace) > {{ .Values.global.cluster.cpu_threshold }}) or
(sum(rate(container_cpu_usage_seconds_total{image!="" , pod=~".*egw.*"}[5m])) by (pod,namespace) > {{ .Values.global.cluster.cpu_threshold }}*2) or
(sum(rate(container_cpu_usage_seconds_total{image!="" , pod=~".*adapter.*"}[5m])) by (pod,namespace) > {{ .Values.global.cluster.cpu_threshold }}*2)
OID 1.3.6.1.4.1.323.5.3.51.29.4002
Metric Used
Note: This is a Kubernetes metric used for instance availability monitoring. If the metric is not available, use the similar metric as exposed by the monitoring system.
Resolution
The alert gets cleared when the CPU utilization is below the critical threshold.
Note: The threshold is configurable in the ocnadd-custom-values.yaml file. If guidance is required, contact My Oracle Support (MOS).
