5 Rolling Back OCNADD
This chapter describes the OCNADD rollback procedure from a target release to a previous supported version.
Table 5-1 Supported Rollback Paths
| Source Release | Target Release |
| 23.3.0 | 23.2.0.0.x |
23.2.0.0.x is the latest patch release on 23.2.0.Rollback Steps
- (Optional) A timeout interval of 15 minutes can be set while performing an upgrade as only one POD of the OCNADD services is upgraded at a time.
- Ensure the status for the target version in the helm history is not in failed or error state.
- Ensure to delete the Kafka feed if enabled on 23.3.0, before attempting the rollback, follow the section 'Disable Kafka Feed Configuration Support' of the Oracle Communications Network Analytics Data Director User Guide.
- Direct Rollback to 23.2.0 is not supported, in such cases firstly rollback to the previous patch 23.2.0.0.x, and then rollback to 23.2.0.
- Run the following command to check the revision to
rollback:
$ helm history <release_name> -n <release_namespace>Where,
<release_name> is the release name used by the Helm command.
<release_namespace> is the OCNADD release name, for example, ocnadd.
Example:
helm history ocnadd --namespace ocnadd-deploySample Helm history output with patch 23.2.0.0.2 example:
REVISION UPDATED STATUS CHART APP VERSION DESCRIPTION 1 Fri May 12 04:57:43 2023 superseded ocnadd-0.0.0-23.2.0 23.2.0 Install complete 2 Fri May 12 05:21:52 2023 superseded ocnadd-23.2.0 23.2.0.0.2 Upgrade complete 3 Fri May 12 05:35:15 2023 deployed ocnadd-23.3.0 23.3.0.0.0 Upgrade complete - Run the command to rollback to the required
revision:
helm rollback <release_name> <REVISION_number> --namespace <release_namespace> --timeout=15mWhere, <REVISION_number> is the release version to which Data Director needs to be rolled back is obtained in the previous step.
For example:
helm rollback ocnadd 2 --namespace ocnadd-deploy --timeout=15m - Run the following command in the charts of previous version to
roll back the Adapter service to the previous
version:
helm upgrade <release_name> -f ocnadd-custom-values-<previous_release>.yaml <helm_chart_previous_release> --namespace <namespace-name> --set global.env.admin.OCNADD_ADAPTER_UPGRADE_ENABLE=true --timeout=15mFor example:helm upgrade ocnadd -f ocnadd-custom-values-23.2.0.0.2.yaml ocnadd --namespace ocnadd-deploy --set global.env.admin.OCNADD_ADAPTER_UPGRADE_ENABLE=true --timeout=15m - Verify if the rollback is successful
- All the pods that has been respawned after upgrade, have the latest age (in secs)
- The Adapter pods also gets respawned for any upgrade.
The status can also be verified from GUI for respective data
feeds.
If the rollback is not successful, perform the troubleshooting steps mentioned in Oracle Communications Network Analytics Data Director Troubleshooting Guide.
