3 Resource Requirement
This chapter provides information about the resource requirements to install and run Oracle Communications Network Analytics Data Director (OCNADD) with the desired Message Per Second (MPS) profiles.
Resource Requirements for CNE Environment
Resource requirements for vCNE (with SSD and NVM):
Table 3-1 CNE Configuration for vCNE
| Type of Server | vCNE with X9 server and NVME |
| Master node | 3 |
| Worker node | 44 |
| Storage Class | Standard |
Table 3-2 Bare Metal Environment
| Type of Server | X9 Server and NVME |
| Master node | 3 |
| Worker node | 19 |
Resource Requirements for OCI Environment
- OCI block volume is attached to the PVC with auto-tune based performance from balanced to high performance. To change block volume to auto-tune based performance (Balance to High Performance), see Changing the Performance of a Volume.
- All tests are performed with the default round-robin based ordering.
- Resource requirements may vary after enabling key or custom based ordering and running traffic with actual NFs.
Table 3-3 OKE Worker Nodes
| Worker nodes | 6 |
| Instance Shape | VM.Standard.E4.Flex |
| OCPUs in worker node | 50 (CPU: 100) |
| Memory in worker node | 194 GB |
