Defining Design Studio for Activation Preferences
To define Design Studio for activation preferences:
From the Window menu, select Preferences.
The Preferences dialog box appears.
In the left-column menu tree, expand the Oracle Design Studio folder.
Click Activation Preferences and define preferences for Design Studio for ASAP.
When finished, click Apply.
Click OK.
Clean and rebuild the projects in the workspace.
