Configuring Network Element Instance Throughput Control
To configure the throughput control for a network element instance:
In the NE Template editor, modify the throughput properties used to create new network element instances.
When modifying the properties used to create new network element instances, you ensure that any future network element instances use the appropriate throughput properties. To do this, update the throughput values in the NE Template editor as follows:
In the Throughput field, enter the maximum number of transactions.
Valid Throughput field values range from 1 - 9999.
In the Transactions Per field, enter the unit of time.
In the Network Element editor, modify the throughput properties for any existing network element instances of that type.
Update the throughput values as follows:
In the Dynamic NE Template editor, modify the throughput properties for any existing Dynamic NE Template used for network element instances of that type.
Save all modified network element templates, network elements, and dynamic network element templates.
You can now deploy the configuration to an ASAP environment for testing.
