Loading XML String Parameter into XML Related Technologies
The autogenerated code produces content in string format for all parameter types including the XML run-time parameter type. However, some network elements require different XML technologies such as document object model (DOM), simple API for XML (SAX), XML beans, and so on. You can create Java code to perform this conversion.
For example, the following sample code loads an XML string parameter into a XML DOM parameter:
public Document buildDocumentFromString(String xmlString)
throws Exception
try
StringReader stringReader = new StringReader(xmlString);
SAXBuilder builder = new SAXBuilder();
Diagnosis.diag(1, this, "Building document for :\n" + xmlString);
Document doc = builder.build(stringReader);
return doc;
catch (Exception e) {
String exceptionMessage = "Exception caught : " + e.toString();
Diagnosis.diag(1, this, exceptionMessage);
throw new Exception("XML Error" + exceptionMessage);
}Related Topics
