Creating Event Templates
Event templates enable you to customize the parameters that are returned when an ASAP event is triggered. If there is no matching template for an event type, no parameters are returned.
To create an event template:
From the Studio menu, select Show Design Perspective.
From the Studio menu, select New, then select Activation, and then select Event Template.
Select a project for this element and enter a name for the entity.
(Optional) Select a location for the entity.
By default, Design Studio saves the entity to your default workspace location. You can enter a folder name in the Folder field or select a location different from the system-provided default. To select a different location:
Deselect the Use recommended name and location check box.
Click the Folder field Browse button.
Navigate to the directory in which to save the entity.
Click OK.
Click Finish.
In the Studio Projects view, in the project folder, the new event template entity appears.
See ASAP System Administrator's Guide and ASAP Developer's Guide for more information on event templates.
Related Topics
