Creating an Activation IP Service Activator Project
You must create an Activation IP Service Activator project in Design Studio before you can import CTM templates.
To create an Activation IP Service Activator project:
  1. Switch to the Studio Projects view.
  2. From the Studio menu, select New, then Project, then Activation IPSA Project.
    The Activation IPSA Cartridge Project wizard appears.
  3. Do the following:
    1. In the Project name field, enter a name for your project.
    2. (Optional) Deselect Use default location and specify a location to save your project. By default, Design Studio saves the project to your default workspace.
    3. (Optional) In the Package field, enter the package name.
    There is no need to modify the Java settings for activation IP Service Activator projects.
  4. Click Finish.
    The activation IP Service Activator project is displayed in the Studio Projects view. You can now import CTM templates into Design Studio.
