Creating New NE Connection Handlers
To create a new NE Connection Handler entity:
From the Studio menu, select New, then select Activation, and then select NE Connection Handler.
The NE Connection Handler Wizard appears.
Select the project for this element and enter a name for the entity.
(Optional) Select a location for the entity.
By default, Design Studio saves the entity to your default workspace location. You can enter a folder name in the Folder field or select a location different from the system-provided default. To select a different location:
Click the Folder field Browse button.
Navigate to the directory in which to save the entity.
Click OK.
Click Finish to create the NE Connection Handler.
Related Topics
