DN Routing Map Editor Editor Tab
Use the Editor tab for defining the parameters for routing an atomic action using DN. In the Routing Map Details area, you can configure the values for a DN routing map entity.
Field Use
Description
Specify a description for the DN Routing Map editor.
Vendor, Technology, and Software Load
Displays the vendor, technology, and software load for the DN routing map entity in the cartridge project.
NPA, NXX, Min Line, Max Line, Atomic Action, and Network Element ID
Displays the values configured in the Routing Map Details area.
Add
Click to add DN routing details for an atomic action.
Remove
Click to clear DN routing details for an atomic action.
Routing Map Details
Field Use
NPA
Specify a Numbering Plan Area (NPA) code. The allowed range is from 100 to 999.
NXX
Specify a Central Office code also known as prefix. The allowed range is from 100 to 999.
Min Line
Specify the lowest line number in the range. The allowed range is from 1000 to 9999.
Max Line
Specify the highest line number in the range. The allowed range is from 1000 to 9999.
Atomic Action
This field is optional. Select an atomic action which you want to route using DN. If no atomic action is selected, all atomic actions in the work order will be routed using DN.
Network Element ID
Select a network element to which you want to route the atomic action.
