Configuring ASAP Servers to Restart After Cartridge Deploy
Use the RESTART_ASAP_SERVERS variable, in the Cartridge Management Variables tab on the Studio Environment editor, to enable ASAP servers to automatically stop and restart after deploying a cartridge.
To enable the RESTART_ASAP_SERVERS variable:
From the Studio Environment Editor, select the Cartridge Management Variables tab.
Select the RESTART_ASAP_SERVERS variable from the Cartridge Management Variables list.
In the Environment Cartridge Management Variable Details area, click Override.
In the Override field, enter true.
When this attribute is enabled, the ASAP servers restart after deploying an ASAP cartridge. This also means that you cannot deploy additional cartridges until the ASAP servers have restarted. Attempting to deploy an ASAP cartridge too quickly after deploying the initial cartridge will result in a deployment failure message.
Related Topics
