NE Connection Handler Editor Editor Tab
Use the Editor tab for defining the parameters for an NE Connection Handler. In the Connection Handler Detail area, you can define the class for the NE Connection Handler entity.
| Field | Use |
Description |
Specify a description for the NE Connection Handler editor. |
Connection Handler Type |
Select any one of the following Connection Handler types from the list:
Vendor, Technology, and Software Load |
In the Connection Handlers area, on clicking Add, displays the vendor, technology, and software load for the NE Connection Handler entity in the cartridge project. |
Class |
In the Connection Handlers area, displays the class you have selected or created in the Connection Handler Details area. |
Add |
Click to add a Connection Handler. As there are different ways of communicating like SOAP, Telnet, and so on, you can add or select a Connection Handler implementation for the Connection Handler. |
Remove |
Click to clear a Connection Handler from the editor. |
Open |
Click to open the code of the Connection Handler class. This button is enabled only when the code is available. |
New |
Click to create a connection class. The connection class contains the skeleton of the connection logic based on the connection type selected on the Studio Activation Java Connection Handler Wizard. Note: New is grayed out for Login State Table Connection Handler and Logoff State Table Connection Handler types. |
Select |
Click to select an existing class. |
