NEP Map Editor
Use the NEP Map editor to map network elements to a NEP and deploy the network elements.
Field | Use |
Description |
Specify a description for the NEP Map editor. |
Default NEP |
Select an NEP as default from the available list of NEPs in the ASAP environment. |
Refresh |
Click to retrieve a fresh list of NEP server names from the ASAP environment. |
Connect |
Click to connect to an ASAP environment using WebLogic Server user name and password. |
Environment |
Displays the name of the Studio environment selected on the NEP Map Wizard. |
Add |
Click to add an network element entity to the Network Element Processor Map grid. |
Remove |
Click to remove an network element entity from the Network Element Processor Map grid. |
Deploy |
Click to deploy a specific network element to the ASAP environment. |
Deploy All |
Click to deploy all the network elements on the NEP Map editor to the ASAP environment. |
Undeploy |
Click to undeploy a specific network element from the ASAP environment. |
Undeploy All |
Click to undeploy all the network elements from the ASAP environment. |
Network Element and Cartridge |
Displays the network element entity name and the cartridge name to which the network element belongs. |
NEP Server |
Select a NEP server for a specific network element on the Network Element Processor Map grid. |
Related Topics
