Defining Upstream Interface Parameters Manually
To define upstream interface parameters manually:
  1. On the Service Bundle editor, click the Upstream Interface tab, and then click Add in the Service Bundle Details area.
  2. In the Upstream Interface Details tab, enter the following information:
    • In the Name field, enter the name of the upstream parameter.
    • In the Default field, enter the default value of the upstream parameter. If the upstream parameter does not have a value, the default is supplied to ASAP.
    • In the Data Type field, enter the parameter's data type.
    • Select Multi Instance if the specified label is the stem of a series of parameters. This allows for a dynamic number of instances and possible use with ASAP's indexing capability for spawning multiple atomic actions.
    • Enable Required if this upstream parameter is required.
Related Topics
Working with Upstream Interface Parameters
Importing Upstream Parameters
Mapping Upstream Interface Parameters to Service Action Parameters
