About Design Studio Builder
Oracle Communications Design Studio builder generates several artifacts automatically every time you create a cartridge or make a change to a cartridge. You can access the following artifacts from the Package Explorer view of the Java perspective or from the Navigator view of the Resource perspective:
The cartridge archive file that Design Studio sends to the run-time server when deploying a cartridge. The file is located in the cartridgeBin folder.
A pre-compressed version of the cartridge archive file, which contains all folders, subfolders, and files in the archive. This directory is contained in the cartridgeBuild folder. When you make a change to a cartridge, the Design Studio builder process makes changes in the cartridgeBuild folder, then it builds the file.
The Design Studio Builder process is automated; consequently, you should not make any changes in the cartridgeBuild or cartridgeBin folders (any changes you make will be overwritten) or check these files into source control.
