About Optimize Deploy
When you enable Optimize Deploy, Design Studio detects any changes you've made to the cartridge, and deploys to the run-time environment only the artifacts related to those changes, whenever possible.
Optimized Deploy reduces deploy times by skipping optional steps in the build and deploy process. If Optimized Deploy fails to deploy the complete cartridge, run a clean build, then attempt to deploy.
The cartridge and environment combination is persisted for each workspace. Each time you start Design Studio, the system uses your previous cartridge and environment selection combinations.
