Studio Environment Editor Cartridge Management Variables Tab
Use the Cartridge Management Variables tab to review and override cartridge-specific cartridge management variables defined for all of the cartridges in the workspace.
| Column | Use |
Cartridge Management Variables area |
Displays the name of the variable and environment-specific values, if defined in the Override field. Design Studio displays all cartridge management variables that are defined in the workspace. The values in this table are read-only. You can change the default value defined for a variable by selecting the Override option and entering a new environment-specific value. Note: If no override value is defined, Design Studio uses the default value defined for the cartridge selected for deployment. |
Environment Cartridge Management Variable Details area |
Displays the name and value of the selected variable in the Cartridge Management Variables area. Do any of the following:
Related Topics
