Conceptual Model Editor Components Tab
Use the Components tab to associate a conceptual model entity to other conceptual model entities. For example, on the Resource Facing Service editor Components tab, you associate with the RFS all resources that are needed to configure the associated service.
When modeling data in the Components tab, see the following topics:
