Creating Simple Data Elements, Structured Data Elements, and Data Structure Definitions
When modeling data for a project, you can create simple data elements, structured data elements, and data structure definitions that you can reuse throughout your model. Also, you can define values for data elements, called enumerations, that are available for selection in a run-time environment.
When creating simple data elements, structured data elements, and data structure definitions, see the following topics:
