Dictionary View Preferences Page
Use the Dictionary View Preferences page to configure the manner in which Design Studio initially filters the entities that appear in the Dictionary view, when viewing entity types in an editor that is linked to the Dictionary view.
| Field | Use |
Select All Cartridge Project Type |
Select an option to define filter options for entities in a specific project type. |
Default Entity Filter Types |
Displays the entity types that initially appear in the Dictionary view, when viewing entity types in an editor that is linked to the Dictionary view. |
Remove |
Click to remove a filter type from the entity type configuration. |
Select |
Click to add additional default entity filter types to the entity type configuration. |
Related Topics
