Notes Tab
Use the Notes tab to add documentation to an entity or data element. For example, you can contribute content to Design Studio reports by writing your own internal documentation about entities and data elements, and you can format the documentation using plain text or simple HTML.
Design Studio supports multiple languages for this tab. The field at the top of this tab displays your list of languages. If your preferences are set up to work in one language only, the system displays only the [default] option. See "Defining Language Preferences" for more information.
Inherited data elements are read-only.
