About the Design Studio Reports
Design Studio includes a set of report designs that you can use as delivered or as a starting point for customizing your own reports. Most reports can be generated in a number of different output formats, which will appear as options in the Generate Report wizard. Report content may be better suited to one format over another. For example, a report may be available to generate in a number of output formats, such as HTML or Open Office Text (ODT), but designed to display best in PDF format.
Design Studio includes the following reports:
Comprehensive Entity Standard Detail Report: Provides root data element details for entities and entity relationships.
Conceptual Model Overview: Provides an overview of your conceptual model, including information about Product, Customer Facing Service, Resource Facing Service, Resource, and other supporting entities.
Data Model Report: Provides a detailed view of simple and structured data elements.
Entity Summary Report: Provides a summary of entities and entity relationships.
Project Summary Report: Provides an overview of projects and project dependencies.
Design Studio Model in XML Report: Provides XML output of Design Studio projects.
Entity and Element Type Reference Report: Provides a list of entity and element types available for reporting.
