Provider Function Editor Inputs Outputs Action Tab
Use the Inputs Outputs Action tab to define the conceptual model entities and the associated action types that the provider function requires as input and generates as output.
| Field | Use |
Input Types |
Displays the types of conceptual model entities that the provider function recognizes as input values. Click the Add and Remove buttons to extend or filter the list of acceptable entities. For example, the Calculate Service Order provider function only recognizes Product entities as input. |
Input Type Details |
Displays the conceptual model entity type and associated action type of the conceptual model entity displayed in the Input Types area.
Output Types |
Displays the types of conceptual model entities that the provider function generates as output. Click the Add and Remove buttons to extend or filter the list of generated entities. For example, the Calculate Service Order provider function only recognizes products as input, and generates only the actions associated with Customer Facing Service and resources. |
Output Type Details |
Displays the conceptual model entity type and associated functional area of the conceptual model entity displayed in the Output Types area.
Related Topics
