Realizing Conceptual Model Entities Manually
If the default design pattern associated with a conceptual model entity is not suitable to your business needs, you can realize conceptual model entities manually.
To realize conceptual model entities manually:
  1. In the Solution view, right-click a conceptual model entity and select Add, and then select Add Realization.
    The Add Realization dialog box appears.
  2. Do one of the following:
    • Select an existing application entity to realize the conceptual model entity and click OK.
    • Click New to create a new entity to realize the conceptual model entity.
    Design Studio creates the application entity in your workspace and adds the realized entity to the Solution view as a child of the conceptual model entity. Double-click the realized entity to open and modify the entity in the appropriate editor.
    The synchronization features are not available for entities that you realize manually.
