Renaming Entities and Data Elements
You can rename entities and data elements and update all references to the new name.
See "Renaming Conceptual Model Entities and Realized Application Entities" for information about renaming conceptual model entities that you have previously realized as application entities.
To rename entities and data elements:
  1. Select an entity from a Design Studio view or a data element from an editor data tree or from a Design Studio view.
    See "Design Studio Common Editor Tabs" for more information about editor data tree areas.
  2. Right-click and select Refactoring, and then select Rename.
    The Refactoring dialog box appears.
  3. In the Name field, enter a new name for the data element.
  4. Click Next.
    Design Studio displays a list of all the changes to be performed.
  5. Deselect any changes to be performed to exclude specific instances from the refactoring.
    Deselecting elements that are referenced can cause model integrity violations.
  6. Click Finish.
  7. Design Studio updates the data element name for all selected references.
