Selecting Entity Types
In some scenarios, you must select an entity type to access the appropriate Design Studio entity creation wizard. You select entity types in the New Studio Entity wizard.
To select an entity type for creation:
In the New Studio Entity wizard, select an entity type in the Entity Type field.
Click Next.
The appropriate entity wizard appears. For example, if you select Process in the Entity Type field, the Process wizard appears.
