Creating Conditions for Network Integrity
To create conditions:
On the Action editor Conditions tab, click Add.
The Create Condition dialog box appears.
In the Name field, enter a name for the condition.
(Optional) In the Description field, enter a description for the condition.
Click OK.
Implement the condition:
In the Implementation Class field, select or create an implementation class.
The condition is implemented in Java.
(Optional) In the Input Parameters field, add the output parameters from preceding processors from which the condition needs information.
This condition can be applied only the to processors that have access to this input parameter.
Click OK.
Save the action.
