Adding Result Sources to Network Integrity Actions
Design Studio uses result sources to link results produced by assimilation, discovery, or import actions to discrepancy detection and discrepancy resolution actions.
Discrepancy detection and discrepancy resolution actions must have result sources.
To add a result source to an action:
  1. On the Action editor Result Source tab, click Add.
    The Select Result Source dialog box appears.
  2. Click Select.
    The Select Action dialog box appears, showing all assimilation, discovery, and import actions available as result sources.
  3. Select an action from the list and click OK.
    The Result Category list shows all result categories generated by the action.
  4. Select the check box beside each required category.
    Leave the check boxes empty to select all result categories.
  5. Click OK.
  6. Save the action.
