Adding Scan Parameter Groups to Network Integrity Actions
Scan parameter groups allow you customize the Network Integrity UI by adding input fields for configuring assimilation, discovery, and import scans.
This procedure assumes that you have already created scan parameter groups.
To add a scan parameter group to an action:
  1. On the Action editor Scan Parameter Group tab, click Select.
    The Add Entities dialog box appears. The dialog box lists scan parameter groups from the current cartridge project and from dependent cartridge projects. See "Managing Project Dependencies" for more information.
  2. From the Matching Items list, select a scan parameter group.
    You can filter the Matching Items list by typing in the Select an item to open field.
  3. Click OK.
    Design Studio adds the scan parameter group to the action.
  4. To organize the order of the scan parameter groups, select a scan parameter group and click Move Up or Move Down.
  5. Save the action.
