Adding Existing Characteristics to Configuration Items
To add existing characteristics to configuration items:
  1. In the Solution view, double-click any entity configuration specification.
    The entity Configuration Specification editor opens.
  2. Click the Details tab.
  3. In the Details tab data tree area, right-click a configuration item and select Select Characteristic.
    The Select Characteristic dialog box appears. See "Select Characteristic Dialog Box" for more information.
  4. Select a characteristic from the list and click OK.
    The characteristic is added to the configuration item in the Details tab data tree.
  5. From the File menu, select Save.
