Associating a Process Specification to an Engineering Work Order Specification
You associate a Process specification with an Engineering Work Order specification to define the process flow for work orders based on that specification. (In UIM, process flows are called workflows.) You can associate an existing Process specification or create a new one. An Engineering Work Order specification is empty until you associate a Process specification with it.
To associate a Process specification:
In an Engineering Work Order editor, click the Properties tab.
Do one of the following:
To select an existing Process specification:
Click the Select button.
The Select Process dialog box appears.
Select a Process specification, and then click OK.
To create a new Process specification:
Click the Process link.
The Process Wizard dialog box appears.
Enter a name, and then click Finish.
The dialog box closes and the Process specification name is displayed in the Process field on the Properties tab. You can click the Process link to open the editor for the Process specification.
