Capacity Required Specification Editor Properties Tab
Use the Properties tab to create a new capacity type or select an existing one.
| Field | Use |
Capacity Type |
Determines the type of capacity offered, defined by a capacity type. Do one of the following:
Required Amount |
Enter the amount of the capacity type that an entity requires. |
Unit of Measure |
Select the units by which the total amount is measured, defined by a Unit of Measure specification. Do one of the following:
Quantity |
Specify the quantity of the required amount. Typically, this value is set to 1. If the capacity required must be consumed as a set of units, such as channels provided by a facility pipe, set the Quantity to the number of units required. The capacity required of each unit is equal to the value set in the Required Amount field. The total amount of capacity required is equal to the value defined in the Required Amount field times the value defined in the Quantity field. |
