Specifying Validity Dates for Characteristics
You can specify validity dates for characteristics. Validity dates can be set for characteristics of all primitive and control types.
Validity dates are not the same as the date range that you specify when you set a characteristics control type to Calendar.
You do not have to specify both a start and end date. You can specify only one. For example, you can specify a start date but no end date.
To specify validity dates for a characteristic:
From the Studio menu, select Show Design Perspective.
Click the Dictionary tab.
Select the data element that you want to tag as a characteristic.
The Data Element tab appears in the Data Schema editor.
Click the Characteristics tab.
To specify a start date, do the following:
Select the Start Date check box.
Enter or select a date on which the characteristic becomes valid.
To specify an end date, do the following:
Select the End Date check box.
Enter or select a date after which the characteristic becomes invalid.
From the File menu, select Save.
