Creating a Checklist
To create a checklist:
Repeat the following steps for each item you want to include in the checklist:
Create a Checklist specification.
In the Properties tab, click Add.
The Checklist Item dialog box appears.
Enter a description for the checklist item, and then click OK.
The dialog box closes and the Checklist Items table displays the item you added.
(Optional) To adjust the order of the checklist items, select an item and click Move Up or Move Down.
(Optional) To remove an item from the checklist, select it and click Remove.
