Configuring a Role Specification
When configuring Role specifications, you specify role types and valid entity types.
To configure Role specifications:
  1. Create a new Role specification or navigate to the editor of an existing one.
    See "Creating New Specifications" for more information.
  2. In the Role Specification editor, click the Properties tab.
  3. In the Role Type field, select Technology, Function, Topology, or Target.
    See "About Role Specifications" for more information.
  4. In the Available Entity Types list, select the entity type or types that you want to be able to have this role.
  5. Click the right arrow button to move the entity types to the Selected Entity Types list.
    If necessary, you can use the left arrow button to move entity types back to the Available Entity Types list.
  6. From the File menu, select Save.
Related Topics
Role Specification Editor
