Configuring Capacity Provided Specifications
You associate Capacity Provided specifications to specifications of entities that offer capacity through the capacity framework.
To configure a Capacity Provided specification:
Create a new Capacity Provided specification or navigate to the editor of an existing one.
See "Creating New Specifications" for more information.
In the Capacity Provided editor, click the Properties tab.
In the Capacity Type field, do one of the following:
Click Capacity Type to create and add a new capacity type. See "Creating Capacity Types" for more information.
Click Select to select an existing capacity type. The Capacity Type dialog box appears, listing all available capacity types.
Click Clear to remove a previous selection.
In the Total Amount field, enter the amount of the capacity provided.
In the Unit of Measure field, do one of the following:
Click Unit of Measure to create and add a new unit of measure. See "Creating Units of Measure" for more information.
Click Select to select an existing unit of measure. The Unit of Measure dialog box appears, listing all available units of measure.
In the Consumable Percentage field, enter the percentage of the total amount that can be consumed.
From the File menu, select Save.
Related Topics
