Configuring Capacity Types
You associate a measurement type to a capacity type to specify how the capacity is measured.
To configure a capacity type:
  1. Create a new capacity type or navigate to the editor of an existing one.
    See "Creating Capacity Types" for more information.
  2. In the Capacity Type editor Properties tab, enter a name for the capacity type in the Name field.
  3. In the Measurement Type area, do one of the following:
    • Click Select to select an existing measurement type. The Measurement Type dialog box appears, listing all available measurement types.
    • Click the Measurement Type link to create and add a new measurement type. See "Creating Measurement Types" for information about creating a new measurement type.
    The measurement type you select or create is displayed in the Measurement Type field.
  4. In the Description field, enter a description of the capacity type.
  5. From the File menu, select Save.
Related Topics
Capacity Type Editor
