Configuration Specification Editor Rules Tab
Use the Rules tab to extend or customize a UIM specification by adding extension points and rulesets.
| Field | Use |
Ruleset Extension Points |
Displays the ruleset extension points that are added to a UIM specification. |
Cartridge |
Displays the name of the cartridge project into which the ruleset extension point is built. |
Select |
Click to select a ruleset extension point that you want to add to a UIM specification. |
Remove |
Click to remove a ruleset extension point that is already added to a UIM specification. |
Add |
Click to add a new ruleset extension point to a UIM specification. |
