Configuring a Sequence Specification
After you create a sequence specification, you must configure it.
To configure a sequence specification:
Open an existing Sequence specification or create a new Sequence specification.
See "Creating New Specifications" for more information.
In the Sequence Specification editor, click the Specification Properties tab.
Enter the start date, end date, and description.
Click the Properties tab.
Enter the minimum value, maximum value, and increment value.
From the File menu, select Save.
Related Topics
