Configuration Specification Editor Tags Subtab
Use the Tags subtab to associate a tag with a configuration item.
Field | Use |
Name |
Displays the list of tags associated with the selected configuration item. |
Description |
Displays a description of the tag that will appear in the UIM run-time application. |
Build Directives |
Indicates whether the user-defined tag is associated with the system-delivered Generate Inventory Runtime Tag tag. |
Remove |
Click to remove the association of the selected tag. |
Add |
Click to associate a user-defined tag with the configuration item. |
