Adding Existing Configurations to a Network Specification
You can add existing network configurations to a Network specification. The network configuration and the Network specification do not have to be in the same project.
To add an existing network configuration to a Network specification:
Open a Network Specification entity in the Network Specification editor.
See "Creating New Specifications" for information about creating new Network specifications.
Click the Network Configurations tab.
Click Select.
The Add Entity dialog box appears.
Select the network configuration and click OK.
The Network Configuration specification is added to the Network specification's Network Configurations tab.
From the File menu, select Save.
