Adding a Configuration to a Pipe Specification
You can add an already existing pipe configuration or create one in the process of adding it. The pipe configuration and the Pipe specification do not have to be in the same project.
To add a pipe configuration to a Pipe specification:
Create a new Pipe specification or navigate to the editor of an existing one.
See "Creating New Specifications" for more information.
In the Pipe Specification editor, click the Pipe Configurations tab and do one of the following:
Click Select to add an existing configuration. The Add Entities dialog box appears, listing the available specifications.
Click Add to create and add a new configuration. See "Creating Configuration Specifications" to create the configuration. When you have completed working on the new configuration, return to the Pipe Specification editor.
The Pipe Configuration specification is added to the Pipe specification's Pipe Configurations tab.
From the File menu, select Save.
