Adding Existing Configurations to a Service Specification
You can add existing service configurations to a Service specification. The service configuration and the Service specification do not have to be in the same project.
To add an existing service configuration to a Service specification:
Open an existing Service Specification entity in the Service Specification editor or create a new Service Specification entity.
See "Creating New Specifications" for more information.
Click the Service Configurations tab.
Click Select.
The Add Entities dialog box appears.
Select the service configuration and click OK.
The service configuration you selected appears in the table.
From the File menu, select Save.
