Copying Existing Product Specifications into an Inventory Project
Product specifications are included in Design Studio for Inventory for backward compatibility with customized solutions that require mapping services to corresponding products.
If you require Design Studio for Inventory Product specifications for backward compatibility, and if you have existing Product specifications in your workspace that you want to continue to use, you can copy the existing Product specification to a new Inventory project.
To copy existing Product specifications to a new Inventory project:
In the Solution view, locate the existing Inventory Product specification in your workspace.
Right-click the Product specification and select Copy.
Right-click the target Inventory project and select Paste.
Click Save.
