Creating Rulesets
You create rulesets to control actions on entities at specific times and under specific conditions.
To create a ruleset:
From the Studio menu, select New, then select Inventory, then select Administration, and then select Ruleset.
The Ruleset Wizard dialog box appears.
From the Project drop-down list, select the project where the entity is to reside.
In the Name field, enter the name of the ruleset.
For a ruleset entity, the text editor forces you to enter all capitals. Use underscores for readability, such as MY_RULE_SET.
(Optional) Select a location for the new ruleset.
By default, Oracle Communications Design Studio saves the entity to your default workspace location. You can enter a folder name in the Folder field or select a location different from the system-provided default. To select a different location:
Click the Folder field Browse button.
Navigate to the directory in which to save the entity.
Click OK.
Click Finish.
