Defining Characteristic User Interface Settings
You define user interface settings for each characteristic to determine how the characteristic appears and behaves on each page and panel in UIM.
To define characteristic user interface settings:
In a Specification editor, click the Layouts tab.
In the Selected column, select a characteristic.
The configurable options for the characteristic appear in the UI Settings area.
You can configure user interface settings only for characteristics.
Define the user interface options for each characteristic.
See “Settings Tab" for information about the options.
From the File menu, select Save.
