Create Diagram Specification
To create capacity types:
From the Studio menu, select New, then select Inventory, then select Resources, then select Diagram Specification.
The Diagram Specification Wizard appears. An icon for the specification type appears in the upper-right corner.
In the Project field, select the name of the project to which the new diagram specification should be added.
In the Name field, enter a name for the capacity type.
This is the name that will appear in UIM.
(Optional) Select a location.
By default, Design Studio saves the entity to your default workspace location. You can enter a folder name in the Folder field or select a location different from the system-provided default. To select a different location:
Click the Folder field Browse button.
Navigate to the directory in which to save the entity.
Click OK.
Click Finish.
Design Studio creates the diagram specification and displays the information in Diagram Specification editor.
