Extension Point Editor
Use the Extension Point editor to define point names, descriptions, and method signatures for extension points.
| Field | Use |
Point Name |
Enter a name for the extension point. |
Description |
Enter a description for the extension point. |
Global |
Select if the extension point will not be associated with a specific specification type (or with a specific set of specifications). |
Signature |
Define a method signature for an extension point. |
