Adding Existing Configurations to a Logical Device Specification
You can add existing configurations to a Logical Device specification. The Logical Device configuration and the Logical Device specification do not have to be in the same project.
To add an existing Logical Device Configuration to a Logical Device specification:
Open a Logical Device Specification entity in the Logical Device Specification editor.
See "Creating New Specifications" for more information.
Click the Logical Device Configurations tab.
Click Select.
The Add Entities dialog box appears.
Select the configuration and click OK.
The logical device configuration you selected appears in the Logical Device Configurations tab.
From the File menu, select Save.
