Adding Existing Configurations to a Logical Device Account Specification
You can add existing configurations to a Logical Device Account specification. The Logical Device Account configuration and the Logical Device Account specification do not have to be in the same project.
To add an existing Logical Device Account Configuration to a Logical Device Account specification:
Open a Logical Device Account Specification entity in the Logical Device Account Specification editor.
See "Creating New Specifications" for more information.
Click the Logical Device Account Configurations tab.
Click Select.
The Add Entities dialog box appears.
Select the configuration and click OK.
The logical device account configuration you selected appears in the Logical Device Account Configurations tab.
From the File menu, select Save.
